No internet, no email confirmation
- My Order
- No internet, no email confirmation
- « Previous
- 1
- 2
- Next »
Re: No internet, no email confirmation
20-09-2019 11:54 AM
Haven't heard anything yet, just wanted to know if everything sorted out yet?
20-09-2019 1:31 PM
Hi @Barkis1
Just got in the office now and I can see the job has been assigned to an engineer as of 09:33:22 this morning.
I'll keep an eye on this for updates although you'd likely know sooner as your broadband should start working once they've hopefully managed to fix the issue.
20-09-2019 2:47 PM
Hi @Barkis1 Engineer notes say they've fixed the problem at the cabinet and it looks like you're online now:
I'd like to sincerely apologise again that it took us 20 days to provide you with a service at your new address and I've made you an offer for a gesture of goodwill which you can view and reply to from Here.
I hope this helps.
20-09-2019 3:35 PM
But before I go I just wanted to know if my internet speeds are going to improve atleast a little bit as it is really really slow.
Thank you again.
20-09-2019 4:56 PM
Thanks for getting back to me @Barkis1 not a problem, I'm just glad to see you up and running now. If you're happy to accept the gesture of goodwill would you possibly be able to reply to the ticket 194069379 linked above? Just to keep things documented on your account.
Line tests are showing your download speeds at around 18.2mbps and upload speed of 1.3mbps which seem to be within the expectations for the length and quality of your line.
While we can't report a fault with our suppliers based solely on this unless we're seeing other signs of a fault like your connection dropping, I'd recommend carrying out the troubleshooting steps Here as this may boost your speed up by bypassing any internal wiring which might be affecting your speeds.
Either way it's doubtful you'd get more than 40mbps so I'd also recommend calling our customer options team on 0800 013 2632 to downgrade to our basic fibre package on a cheaper deal.
Let me know how it goes.
- « Previous
- 1
- 2
- Next »
- My Order
