New router associated with someone else's broadband user name
EB1
I have just set up my new router, however I have noticed on the Plusnet Hub under 'my services' that the 'broadband username' associated with the router is someone else's email address. Will this be a problem?
1 REPLY 1
Fixes: 399
Re: New router associated with someone else's broadband user name
If the username is setup@plusdsl.net then it's not a problem as the router should self configure with your username.
If it's different to that and not <youraccountname>@plusdsl.net , then it IS a problem and you need to contact PlusNet
