New customer router not arrived
Keith187
Re: New customer router not arrived
Thanks for your help. I'll try setting up my old bt hub again. I really do need to get my heating on. I haven't been without the Internet since 2000, it's not good. I'll keep trying. Not a great start plusnet.
Fixes: 580
To check that you have the correct username & password , you can try logging in to the memeber centre here https://www.plus.net/member-centre/login
You then use the same username but with @plusdsl.net appended and the password for the router .
Keith187
Yeah I've tried a couple of times but I still get that flashing purple light. The router must be 10 years old.
Keith187
The storm in the uk is bad up north like I said I have no heating the Internet runs the Hive any ideas how to make that run. That's my major concern at the moment.
Thanks for all your help greatly appreciate 🙏
Fixes: 580
Hive will run without internet and should maintain any schedules you alraedy have set. If you need to adjust then you can do it from the Hive thermostat , you just wont be able to control it from the Hive app on a phone.
Fixes: 580
Hive user guides are here https://www.hivehome.com/guides/hive-heating
Keith187
Thank you so much I just pressed it on and did a heat boost schedule not on but at least I can boost. Thank you I didn't think it was working because I tried it through the app don't really touch the stat had to stand on a chair managed it though lol. Thanks again
Fixes: 479
@MisterW wrote:
@Keith187 the BT HUb can easily be reconfiured with your Plusnet login details see here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
I have read that the newer versions of Smarthub can no longer be used on a Plusnet service. As far as I am aware, this has never been confirmed.
However the other common reason it fails is that the instruction to remove the DSL cable before entering the Plusnet credentials is missed.
It is essential that this cable is removed before entering the Plusnet credentials and only reconnected after the settings have been saved. It cannot be done whilst the hub is 'on line'.
Fixes: 580
@Keith187
Glad we got you some heating!. If you don't mind me saying,  I think perhaps you should get someone to put the stat in a more accessible place.
@Baldrick1
I thought it was said the BT Hub was 10 yrs old so it shouldn't have that problem should it.
The OP is going from a Fibre 150 to Fibre 300 so its going to be an ethernet connection into the WAN port, does that still need to be removed ?
RealAleMadrid
Fixes: 68
@Baldrick1  The OP claims to be using a 10 year old BT Hub on a 150Mbps Full fibre connection and has moved to a Plusnet,  300Mbps service. Not sure if we have the full story here, such as is the Hub that is being set up with Plusnet credentials is the same one that was used on Full Fibre? As you say changing the username and password can only be done when offline, the op will probably not be aware of this.
Fixes: 383
Will a ten year old Hub/router be able to handle 300Mbps?
Fixes: 580
Probably not but, if configured correctly, it will work and give a connection.
... I wonder, is the original 150Mb connection G.fast by any chance which is where confusion is coming in ?
Although I'm not sure a 10yr old router would support G.fast
@Keith187 did your original BT router connect to the BT master socket or did you already have an Full Fibre ONT ?
@Keith187
Can you identify the BT Hub you're trying to use from this site
https://www.bt.com/help/broadband/learn-about-broadband/different-types-of-bt-hub
Fixes: 479
@MisterW wrote:
@Baldrick1
The OP is going from a Fibre 150 to Fibre 300 so it’s going to be an ethernet connection into the WAN port, does that still need to be removed ?
I would assume that it’s the Ethernet cable that must be disconnected. If it’s connected the default username connects to the BT configuration server, where it recognises the request to connect to a non BT service so refuses to play.
From experiments with the Hub One the priority port on switch on is the DSL port, from a factory reset with a live  ethernet link to the WAN port in my case to a PPPoE server, the Hub assumed a WAN connection.
So I would say power the BT Hub with WAN link to the ONT connected once the connection is established with a login failure, force a disconnect by pulling the WAN cable  and then enter the plusnet broadband username and password.
Hope this works.
EDIT: once the Hub One uses the WAN port once it will always do so until factory reset
