New Router not arrived engineer due tomorrow
lscatterson
My new fiber router has not arrived and engineer is due tomorrow. I cannot get through on the phone.
If I try and track my order online but get a message to say I do not have one.
What should I do?
Lawrence
34 REPLIES 34
Fixes: 480
Re: New Router not arrived engineer due tomorrow
@lscatterson
Are you upgradiong to Full Fibre?
If so have you got a Plusnet Hub One? If so that can be used until your Hub 2 arrives. Just remove the DSL lead and connect the red WAN socket to the ONT using a CAT 5E or better Ethernet cable, If you have elected to have one of the fastest FTTP connections there could be limitations on your upload speed.
Moderators Note
This topic has been moved from Full Fibre to My Orders
lscatterson
Thank you for your reply.
I am moving to Broadband: Full Fibre 300, not sure what my current router is but I have had it for about 4 years. How do I tell which one it is
Lawrence
bobpullen
Fixes: 331
@lscatterson - your hub was disapatched last Friday via Royal Mail First Class post.
I can only imagine it has been held up by the strikes.
Will hopefully be with you any day now.
Edit: Forgot to add, you currently have a Hub One. This will work with FTTP by running an ethernet cable between the red WAN port on the back and the Openreach ONT that your engineer will install on the wall. The upload will be limited to 30mbps in this configuration, however it should see you good until your Hub Two arrives.
lscatterson
Thank you for checking, yes the strikes with Royal Mail will not help neither does living in Northern Ireland.
Below is a picture of my current router, will I be able to plug this in to the ONT on the box thats install and still have internet.
I am mainly worriedabout having no internet as I need it for work.
bobpullen
Fixes: 331
@lscatterson - see the edit of my previous post.
dogtired
Will this work with any router? My new router has not arrived.
thanks
Fixes: 390
@dogtired Which router do you currently use?
Fixes: 585
@dogtired it  will work with MOST (except Talktalk/Sky locked) routers, but if it's not a PlusNet supplied one, then there's a little manual configuration required.
Tell us what make/model your router is and we'll try and advise.
dogtired
Hello, it is a John Lewis one, which is really Plusnet. The make is ZYXEL.
THANKS
dogtired
@jab1
ZYXEL John Lewis fibre broadband on the telephone line,
thanks
Fixes: 390
@MisterW ? - I'm not certain.
Fixes: 585
@dogtired  its likely a VMG 3925-B10C then ?
If so it will work fine, although it will need a little configuration. You will need to change the username/password on the broadband settings screen
Are you changing to Full Fibre or staying with normal FTTC ( Fibre unlimited/extra ) ?
dogtired
@MisterW  Yes it is, I am changing to full fibre.
dogtired
@MisterW how do I change those details? Thanks
