New Package Should Have Activated 1st December
Parallax
I upgraded to Full Fibre 900 on 28th November, and received an email saying it would take effect on 1st December. As of the evening of 4th December, it hasn't. The billing area says I'm out of contract, and am now paying a huge amount of money. Any ideas?
7 REPLIES 7
Fixes: 580
Re: New Package Should Have Activated 1st December
Call customer support to check what's happening with the upgrade
Fixes: 1,662
Hey,
I’ve had a look and we currently can’t provide a speed higher than the 500mbps you have. It looks like our suppliers have stopped taking orders for speeds above 300mbps due to a capacity issue at the exchange you’re connected to.
I’d suggest giving us a call on 03301239123 to cancel the upgrade. You’re fine to re-contract on the same package or downgrade though.
Parallax
When you say your supplier, do you mean Openreach? So if I find an ISP that uses a different supplier, I'll presumably be able to get the higher speed?
Fixes: 383
If you can find a supplier who does not use BTOR infrastructure, you will be able to get whatever they offer.
Fixes: 1,662
BT Wholesale. But it’s not permanent, I’m sure capacity will be restored at some point though we don’t know when.
Parallax
Is there any indication as to how long? If it'll just be a month or so, I can probably put up with it. Not so much if it's a year down the line.
Fixes: 1,662
I asked and not as far as I'm aware.
