Need a delayed order to be dealt with.
Jayjay
My phone line has gone live but the broadband side has not and I keep being told it’ll be 24 hours. But that never works out.
Apparently there’s an exception and no KCI3.
please help.
35 REPLIES 35
Fixes: 1,652
Re: Need a delayed order to be dealt with.
I'm really sorry for the delay with your order. I can see we've been escalating this with our suppliers as your order's stuck in the supplier systems, due to a system issue. We'll update you as soon as we know more.
Jayjay
It seems strange that nobody at plusnet can contact OR and make them progress this immediately. So much waiting around.
Now the estimated speed guarantee has halved why?
Fixes: 1,652
I can assure you that we have been contacting Openreach's helpdesk on numerous occasions, however due to the nature of the issue I'm afraid that it's not something which can be fixed immediately, otherwise it would be.
Your estimated speeds are below as per the email we've sent when you signed up.
"At peak times, we estimate that you'll get the following speeds on your line:
Download: 63 - 72Mb
Upload: 17 - 18Mb
Minimum Guaranteed Speed: 57.8Mb"
Really sorry again for the inconvenience. We'll be sure to get you back online as soon as possible.
Jayjay
Appreciate the response and explanation re. OR.
The online account has updated to show these speeds for my line,
Fixes: 1,652
No worries. Let's see what that looks like when your broadband order's completed.
Although the minimum guaranteed speed is only really taken into account if you're looking to leave and if that's the case then we should be looking at what we've confirmed with you in an email.
As for the estimates, these can change as they're the current expectations of a line and they're most up to date on our suppliers broadband availability checker Here.
Jayjay
Hi, the strangest thing has happened with the account. The broadband became active for ~1 week then cut off suddenly and now it’s apparently still an open order with Openreach. And awaiting a KCI3 how can you provide a service for a period off time yet then it can be cut off and plusnet think the line was never active. Please can you help sort this once and for all? Or help find out where the issue lies and get the relevant team to rectify asap.
Fixes: 1,652
I'm really sorry to see what's happened. From what I can see the engineering work has been completed but we've not received a notification (KCI3) from our suppliers to confirm the order's completed.
We had nonetheless prematurely activated your account so you were able to get online.
Unfortunately the lack of the KCI3 notification is stopping us from testing your broadband or reporting a fault to Openreach.
We've continually been chasing this up with our suppliers and they've advised us the order is stuck in their systems, but they've escalated it to the relevant team to sort as soon as possible.
As soon as we know more, we'll let you know.
Jayjay
What I don’t understand is that if you could activate the service and allow me to use it why can’t this be done again and then you will still be able wait for the KCI3 but I’ll have some sort of service.
This seems like a common sense approach here.
Fixes: 1,652
The service is still activated on our side though. There’s a problem somewhere but we can’t run diagnostics or report a fault to identify what the issue is.
Jayjay
Ok, so the two engineers that came out to ‘fix the line’ have not been successful. Why can’t you just order a new line for me so we start from scratch and have a clean fresh line to use?
Fixes: 1,652
Without knowing what the issue is then a new line might not actually work. Ordering a new line installation isn’t as new as you’d expect as in the vast majority of cases, engineers will just reuse spare lines within the existing cabling rather than lay brand new cabling.
A lot more can go wrong with broadband than the line itself, it could be the port in the cabinet or exchange, or a supplier configuration issue to name a few.
Additionally if we were to place a new line installation order then this would generally take 2 to 3 weeks and again may not fix the issue or cause more problems.
Admitttedly I’m not in the office today, but I suspect the engineers we had arranged were on the back of the order? If that’s the case then their work did get you up and running, but now there’s a problem somewhere.
Appreciate the frustration but at this stage persevering with downtime until the order is completed so we have a clearer view of what’s happening is the best way forward.
Jayjay
Appreciate your response and the detail included.
Can you actually find out what is the issue instead of being told KCI3 with exception on order?.
Fixes: 1,652
No problem and I can try but generally for these type of issues, we struggle to get detail from suppliers.
An order goes through various stages in numerous supplier systems which all interact with each other. The main stages are KCI1 (Acknowledged), KCI2 (Committed/Confirmed) and KCI3 (Completed). KCI stands for Keep Customer Informed. The Customer here would be Plusnet, as the KCI’s come from Openreach.
In this case, it’s stuck at the last stage and an exception is usually a system error, which prevents the order from being marked as complete in one or more systems.
I’ll take a look again for you tomorrow when I’m in.
Jayjay
I’ve also weirdly received email this morning to say how my broadband has been up and running for 14 days and that the speed is much higher than expected at 76 Mbps! - what’s happening at plusnet?
