Moving House
Tristramd
Moving House
Hi Smiley
I’ve recently moved house on the 19th and informed plusnet. They couldn’t put a order in until previous occupants Broadband order ceased (Plusnet). Order placed on 20th October (tracking no 5-868746159507). I’ve been told activation date 02/11/2021.
Does it really take 2 weeks for broadband to be activated? This is the longest I’ve had to wait ever, and working from home, my Three mobile signal isn’t great and Teams meetings is embarrassing 😳
Thanks Smiley
11 REPLIES 11
LaurenB
Fixes: 131
Re: Moving House
Hiya @Tristramd, thanks for getting in touch.
Fibre orders do generally take around 7-10 working days to complete as it's depending on engineer availability, I am really sorry for the inconvenience that is caused in the meantime.
Should you have any further queries in the meantime, please do just get back to us!
 Lauren Barry
Tristramd
Re: Moving House
Hi Lauren Smiley
Thanks for your reply :). Can orders sometimes become active before the date, or does it generally become active on the date?
Also my hub is plugged in and powered on, should I turn it off until the 2nd?
Thanks again Smiley
LaurenB
Fixes: 131
Re: Moving House
Thanks for getting back to me.
I'm afraid usually it is the date we have been given that the order completes and likely won't complete sooner Sad It can take up to midnight on the day to complete.
It may be worth turning off your router for the time being as it won't connect until the order is complete anyway.
 Lauren Barry
Tristramd
Re: Moving House
Thank you Smiley
Is it normal not to have a dial tone on the line at the moment?
LaurenB
Fixes: 131
Re: Moving House
Thanks for getting back to me. You would still usually have a dial tone on the line but as the order is still open we're not able to investigate this further at this point.
If once the order completes the dial tone hasn't returned, get back to us so that we can assist you further.
 Lauren Barry
Tristramd
Re: Moving House
I forgot to ask. Does my old telephone number(showing on my account) stay the same or will it change? (Ive only moved 3 doors up lol)
Fixes: 1,662
Re: Moving House
No problem @Tristramd thanks for getting back to us.
Yep I can confirm we're keeping your landline number the same Smiley
Let us know if you've got any further queries.
Tristramd
Re: Moving House
Morning all Smiley
I noticed my hub had connected this morning. Tried a speed test and I’m only getting 37 down and about 10 up (half the speeds) and no dial tone.
Should I wait until the 2nd before logging a fault. Sounds like I’m only getting connection down 1 wire in the pair..
Fixes: 1,662
Re: Moving House
Hi @Tristramd
I'm glad to see you're up and running earlier than we expected although with your service limping away.
Yeah I'd recommend waiting until the order's completed as we can't log a fault with Openreach until it has been.
It can take anytime up to midnight on the 2nd to complete so could you post back on the 3rd?
Tristramd
Re: Moving House
Hi Gandalf
Many thanks for your reply on a Sunday Smiley
I will keep an eye on it and report back.
Ps is it ok for me to use Plusnet now? I’ve been struggling with using my Three network as a hotspot running at 2meg haha
Fixes: 1,662
Re: Moving House
No problem @Tristramd, haha yeah that's perfectly fine. Smiley
