Issue with house move order
goingmissing
I begun a house move order on 11 November and have received my new router and thought everything was in progress.
However I have just seen on the 'Open Questions' on my account that there was a problem with the order. I have received no contact from PlusNet about this, no telephone calls or emails, and now I'm really worried that my house move will not initiate on the day it is needed.
Please could anyone confirm if there's a problem on my account?
The question this relates to is reference 229069487
Many thanks
Rachel
7 REPLIES 7
willcutforth
Fixes: 113
Re: Issue with house move order
Hey there @goingmissing I can see they have since updated the ticket yesterday. Do you need any more help with it?
 Will Cutforth
goingmissing
Hi @willcutforth thanks for your response, the whole order had to be cancelled and put in again but I believe it's been reinstated!
I'm moving into a new build with an ONT box installed and I've had an email saying that an engineer has been booked - do you know if I should expect an engineer visit to the house? If yes, do you know the times the appointments are between so I can make sure I'm at the house? I'm not sure how early they begin. Many thanks!
willcutforth
Fixes: 113
I'll get someone to chase it up for you. Should be within the next few hours when they are in if that's ok?
 Will Cutforth
goingmissing
@willcutforth that would be so helpful, thank you. Just so I know whether to be in or not Smiley
adamwalker
Fixes: 223
Hi @goingmissing, I've just checked and Openreach tell me it's an AM appointment so someone should be with you between 08:00 and 13:00. They should be calling when on their way. - Adam
 Adam Walker
goingmissing
Thank you so much!
adamwalker
Fixes: 223
No worries! I hope it all goes smoothly and do drop us a line on here again if there's any issues.
 Adam Walker
