How long does it take before a request for a static ip is actioned?
Porsmitj2
I recently added a static ip to my account (was charged £5) but it is still showing as dynamic.
How long does it usually take?
Thank you
5 REPLIES 5
Fixes: 385
Re: How long does it take before a request for a static ip is actioned?
Try rebooting your Hub.
Porsmitj2
Still saying I am using dynamic IP
Fixes: 385
@Porsmitj2 Either ring in and query it, or wait for one of the Help Team to pick this topic up.
MatthewWheeler
Fixes: 503
Hi @Porsmitj2
I'm sorry to hear that your static IP hasn't kicked in yet.
I've done some work on your account and it's showing as active now.
If you reboot your router you should pick it up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Porsmitj2
All sorted now.
Thank you
