House Move
ciaranjt97
House Move
I am moving house today, I informed Plusnet around 4 weeks ago, received all of the paperwork etc. However, I haven’t heard anything else from Plusnet, no updates on the order or anything.
My current broadband (at the old property) is still live which leaves me slightly concerned that the switch won’t happen today.
Just need an update on whether the order is on track or not.
5 REPLIES 5
Fixes: 391
Re: House Move
@ciaranjt97 Have you checked for any tickets on your account? This link - https://www.plus.net/member-centre/login?p=search should help.
ciaranjt97
Re: House Move
Thanks for the reply! I have checked the tickets on my account, the only “active” ticket is one from 12th Sept (when I made PN aware of the move), and is just to confirm the new address and the move date.
Fixes: 391
Re: House Move
No 'closed' tickets after that date? If not, I  can only suggest you give them a call.
ciaranjt97
Re: House Move
Thanks, just checked, the only closed tickets are from the 12th Sept regarding the move, nothing since then unfortunately. Will give them a ring this morning, thanks for your help!
Fixes: 391
Re: House Move
No problem - it is a 'Community Forum' after all, where those of us who can, try to help.
