Go Live Today
Fixes: 392
Re: Go Live Today
No you shouldn't, which is why I think you have been wrongly provisioned.
ghamilton123
Re: Go Live Today
Hopefully it sorts itself out, as I've been using 3G all day, will update tomorrow
Mustrum
Fixes: 81
Re: Go Live Today
You have not mentioned but is this a new property to you or are you transferring from another supplier?
You also have not said if you have internet access or if the router is showing your username or is it still on [email protected] or similar.
ghamilton123
Re: Go Live Today
Its a new property to me, its showing my username and I do have internet.
Fixes: 392
Re: Go Live Today
@Mustrum Post #3 clearly shows the Ops connection to be G992.5 ADSL2.
Mustrum
Fixes: 81
Re: Go Live Today
@jab1   yes I am aware, and given the OP has not yet had the go ahead from PN and has been told up to midnight the provisioning has not yet been completed.
Still sounds to me that Openreach have not been to the cabinet.
Fixes: 392
Re: Go Live Today
@Mustrum Could be, but would they receive any service if they had applied for FTTC? I can't see it myself.
RealAleMadrid
Fixes: 68
Re: Go Live Today
@jab1  I've just seen this thread and I would agree with you that it is provisioned incorrectly on ADSL. If FTTC was ordered no ADSL service should be enabled at the exchange. There is next to no chance it will be corrected without cancelling and re-doing the order or maybe the OP could upgrade to FTTC.🙄
Fixes: 392
Re: Go Live Today
Thanks, @RealAleMadrid . His member centre shows him as being provisioned on FTTC though, so something appears to have gone wrong - OR incompetence?
ghamilton123
Re: Go Live Today
Seems to be sorted now, but no emails or texts from plusnet telling me I've went live?
RealAleMadrid
Fixes: 68
Re: Go Live Today
@ghamilton123  That's interesting, so are you on an FTTC service now?  What do the router stats show?
ghamilton123
Re: Go Live Today
Data rate:20 Mbps / 79.999 Mbps
Maximum data rate:23.921 Mbps / 103.771 Mbps
Noise margin:8.0 / 12.0
Line attenuation:8.1 / 16.9
Signal attenuation:8.0 / 18.3
VLAN id:101
Mustrum
Fixes: 81
Re: Go Live Today
Ahem, @ghamilton123  hopefully your go ahead should come through any time soon. No doubt a late in the day Openreach getting to the cabinet, as mentioned.
RealAleMadrid
Fixes: 68
Re: Go Live Today
@ghamilton123  That looks excellent with full 80/20 speeds, you must be quite close to the FTTC cabinet.
I am surprised that the ADSL service was working yesterday with your correct user details, the only plausible explanation I can offer is that there was an existing ADSL connection supplied by Plusnet at the property and you connected to that. If it was any other ISP you wouldn't have been able to log in.
Anyway it's all looking good now so enjoy the speed.😀
ghamilton123
Re: Go Live Today
Not sure where the nearest cabinet is, but there's a exchange just up the road from me from what I know, just hoping we get fibre here soon, moved from gigabit to a area where the only providers are openreach based.
