Full fibre upgrade - replacement router?
paulpud
Having been with Plusnet for 3 years I have just placed my order to upgrade to full fibre. My current router, which I believe is the Hub 2 and is compatible for the new service, does play up occasionally and I usually have to reboot it every few weeks although I did have to do it a couple of times in one week a few months ago.
Would Plusnet provide me with a replacement router if I ask as I am now signing up to a new 2 year contract?
5 REPLIES 5
Fixes: 476
Re: Full fibre upgrade - replacement router?
Moderator's note:
Thread moved from Full Fibre to My Order
pvmb
Aspiring Champion
Fixes: 15
I can't see Plusnet replacing their current router for an identical model simply because of a contract upgrade, unless there is evidence the router may be faulty.
Do you know what was behind the need to reboot? Was it a problem with the router or with your existing telephone line? Remember, with FF you will no longer even be using the existing landline.
paulpud
I'm not sure what has been the cause of the problems in the past but I've always sorted it by rebooting the router. I haven't had to do it for the past few weeks but I was thinking it would be just my luck to have a nice new full fibre service and a failing router.
I have noticed there are a lot of new/unused hub 2 routers for sale on eBay for very little money. I assume I could buy one of those to keep as a back up in case it did fail and just plug it in as a replacement.
Fixes: 147
@paulpud
Have you considered buying your own router, depending on your Full Fibre product choice a third party router might be a better option.
You can keep your current Hub two as a spare.
paulpud
I think getting another router and keeping one as back up will be the solution
