Full fibre being installed soon but router hasn’t arrived
Cris_L
I’m due to have full fibre installed on Tuesday.
I was told a new router would arrive before the installation but nothing has turned up yet.
I currently have the Plusnet one router for the standard broadband. Will this work ok with full fibre if the new one doesn’t turn up? I don’t want to be without internet.
27 REPLIES 27
Fixes: 357
Re: Full fibre being installed soon but router hasn’t arrived
@Cris_L Hubs are despatched via RM Tracked24, scheduled to arrive one or two days prior to your FF installation, so there is still a chance. Is there any information on your account that indicates the Hub2 has been ordered? You should get a text and/or email notification when it is dispatched.
I think the Hub1 will work with FF, but I am not certain, and open to correction.
Mustrum
Fixes: 81
The Hub 1 will work, but your speeds may be restricted if you have gone for one of the fastest packages.
Fixes: 558
@jab1 the Hub 1 WILL work with FF but it is only capable of around 30Mb upstream bandwidth. Only a problem on the higher spec products 300Mb up and even then not a major problem short term.
@Cris_L you will need a spare ethernet cable (cat5e or better) to connect the Hub 1 red WAN port to the ONT.
Fixes: 357
Thanks, @MisterW , and @Mustrum
Cris_L
Thanks all
I can’t find any info about hub 2 being dispatched or not. Is there an area in my account where I can see? I just can’t be left with no internet as I need it for work.
Fixes: 466
Moderator's note:
Thread moved from Full Fibre to My Order
Fixes: 357
@Cris_L I can't point you in the exact area - I'm no longer with PN, so my 'Account' details are not the same as you would see, but maybe somewhere in the 'My Order' or similar area?
But note - as explained above, you current Hub1 will work if you don't have the Hub2 on installation date.
Fixes: 558
@Cris_L I can’t find any info about hub 2 being dispatched or not. Is there an area in my account where I can see? I just can’t be left with no internet as I need it for work.
You should have been sent notification of the router despatch by email (and SMS if you have a mobile no registered)
There will also be a closed question ('ticket') on your account . Check closed tickets by logging in to your member center and then going to https://www.plus.net/wizard/?p=search and then select view closed questions
As has been said above, your Hub 1 router will work.
MatthewWheeler
Fixes: 503
Hi @Cris_L
From what I can see we sent you a Hub Two around a year ago or so.
Can you confirm what the router you're using at the moment looks like?
If it is the Hub Two router you won't get a new router as it'll work fine on Full Fibre you may just need an extra ethernet cable to use between the router and the ONT if you haven't got one already
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Cris_L
Thanks for the reply Matthew.
I don’t recall receiving a router as recently as 12 months ago but I’ve just uploaded a photo of the only one I have which is currently in use. Apologies if it’s the hub 2. I can’t work out how to attach the photo but maybe you could take a look in my account for me?
It is rectangular in shape with Plusnet across the middle and a blue line underneath the text?
Fixes: 357
@Cris_L Are the light along the bottom of the Hub, or in the centre of the front panel?
Edit: That looks like a Hub1, to me.
Cris_L
Fixes: 357
@Cris_L See my edited post above!!
Cris_L
Thanks. That’s the one router I have, pretty sure I’ve had it years tbh.
