Full Fibre upgrade
- My Order
- Re: Full Fibre upgrade
Full Fibre upgrade
4 hours ago
Upgraded to Full Fibre - installed last week but router not received at the time engineer came. He set it up with my existing one and said just replace it when new one arrives.. Router arrived a few days later and i connected it OK.
I have just received an email from Plusnet to say my account is being charged £6.99 postage for the new router.
Is the router not part of the installation?
4 hours ago
What model of router did you have? Irrespective, any router supplied by PN is subject to a P&P charge.
4 hours ago
However, it you already have the same model (hub2) you can return it as not required.
If it is not the same model, best to keep it as PN can troubleshoot using it if you have an issue.
4 hours ago
And, although we don't know what speed the OP has ordered, the H1 is not really suitable for the higher-speed tiers.
3 hours ago
The old and new routers are both Hub 2 but the new one does provide a quicker speed. (up to 300mbps) That is the level I paid for.
The correspondence from Plusnet suggested the engineer may bring it or it would be sent by post to arrive before the engineer arrived. Neither happened. I do not recall any mention of postage charges.
Thanks for your replies.
3 hours ago
If the new one is 'better', then I suggest you return the old one - see https://www.plus.net/help/broadband/plusnet-router/ for details/instructions.
