Full Fibre offer
Fixes: 385
Re: Full Fibre offer
As things stand, @Robin6 , yes, because FTTP  is not available to you.
RealAleMadrid
Fixes: 68
@jab1  If FTTP is not available how can any ISP place an order, it would be rejected. The mystery is how did Plusnet place the initial order, the checker must have incorrectly shown FTTP to be avaialable.
Ian06
Fixes: 6
I don't know if it's relevant but there seems to have been problems with the Openreach Fibre Checker openreach-fibre-checker-broken it seems to be reporting FTTP not available when it is, but could be a wider DB problem?
Fixes: 385
@RealAleMadrid I agree totally, but how that incorrect status got on the BTw checker?...
Fixes: 385
Highly likely, knowing BT/OR.
Fixes: 479
I have just been looking at the Availability Checker and it's had a serious clean up  It now includes, for each property, just the address and UPRN.
I have a friend who's property featured twice, which was caused considerable grief as one with a UPRN showed full fibre to be available, and the one with no UPRN saying not available. The problem was that records showed the connection being to the one without a UPRN, so no FTTP available. This entry with no UPRN has now disappeared.
What might cause issues is that the address recorded in the database might now be different to that recorded in Plusnet records. The key to getting the correct entry in the database in to do a search here: https://www.findmyaddress.co.uk/search. If you can't find your property initially then widen the search and look through all the addresses listed. Once you find a likely address, selecting it shows you the chosen property location on a map. With this you have all that you need to request an ORDI review.
Robin6
Moderator's note:
Full quote of preceding post removed as per Forum rules.
Thank you,
unfortunately every time I try and search find my address it says you’ve reached your 10 limit search, I haven’t
Robin
Fixes: 479
@Robin6
Try clearing your cookies.
Robin6
No still says I’ve reached my limit, cleared history and website data on my iPhone, also tried using desktop website
Fixes: 385
Strange, @Robin6  - works OK for me.
Robin6
I know I’ve also tried on my better half’s iPhone and the same
Fixes: 385
@Robin6 Do you mean it is blocked, or can you use it?
Fixes: 117
@Robin6
If you're happy to PM me with your address and post code I'll have a look for you.
Robin6
Every time I put anything into the search bar it says search limit reached
Fixes: 117
@Robin6
Replied to PM
Edit : If you PM my the house number of your neighbour with OR markings I can check that as well if you'd like.
