Free Router?
Fixes: 388
Re: Free Router?
Why?
cbcadmin
Re: Free Router?
Why what?
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Fixes: 1,664
Re: Free Router?
If it helps, you do have an order for a hub and it should be delivered in time for your activation. Smiley
Fixes: 388
Re: Free Router?
Why doesn't it make it right, is what I asked. The technology/infrastructure used by ADSL/FTTC is end-of-life, and needs updating - hence why everyone, eventually, will be on a version of FTTP.
cbcadmin
Re: Free Router?
It does help, thank you.
cbcadmin
Re: Free Router?
It's not right as it is being forced on people. Some need their copper line for phones, alarms etc. As it stands prices are increasing for less. To many the increase in speed is a good thing, others don't need it.
Fixes: 388
Re: Free Router?
If they don't replace the old, worn out and non-repairable old technology, it will become increasingly unreliable. Phone calls can still be made, but it will not be via the old, increasingly antiquated copper circuits, and alarm companies are updating their systems to accommodate the changes, or already have done so.
