Engineer visit tomorrow
JulieD42
Tomorrow I’ve the engineer coming to install the new cables for our PN 145mb. We were initially told it would be 16th but they it moved to tomorrow. I’ve not heard anything since, will the engineer call tomorrow or just turn up? I did try calling PN tonight but I was on hold for too long. I’m just concerned I’ve heard nothing since the email to say the engineer is coming on 23rd.
Once he leaves do I just plug my router in and I’m now with PN? I’m currently with BT. Will my internet with BT then cease and they will know I’ve left them?
2 REPLIES 2
SammyM
Fixes: 101
Re: Engineer visit tomorrow
Hiya JulieD42,
I'm really sorry for the delay in getting back to you, it is more chocca than usual and I'm sorry for the confusion as to what happens next.
I can see that your order is complete and you should be all up and running, is this the case?
 Sammy M - Sheffield Team
SammyM
Fixes: 101
Hiya @JulieD42,
I just wanted to check if you were up and running?
