Engineer says installation will be a 'massive job'
Fixes: 579
Re: Engineer says installation will be a 'massive job'
but there wasn't any delay to get PTW!. The delay was down to the contractor 'backheeling' it to OR. Once OR decided what needed doing the PTW was given immediately...
jelli
All done and set up. Quite a job in this gale. I can't fault the Openreach team one bit, they were brilliant.
I will wait to see if I get the compensation!
