Engineer says installation will be a 'massive job'
jelli
Hi, I'm new to this, so hello all. I received a message from an engineer who is coming to install full fibre tomorrow. The time booked was confirmed as between 1pm and 6pm though he has said he will be coming in the morning up until early afternoon. Before 1pm isn't great timing for me hence setting it to the afternoon... very confused and fed back that my understanding was that he was coming at the times confirmed. He said it would really help if he could come earlier as it's a massive job. So I'm getting worried now! He said if I'm not in he will come in the morning and sort out the 'externals' without me there and then come back after 1pm to do the 'internals.'
I wondered if this is normal practice... I'm concerned about the 'massive job' as I thought they only need to drill a hole in the wall - which I already have from a previous supply...
Any feedback gratefully received Smiley
46 REPLIES 46
Fixes: 579
Re: Engineer says installation will be a 'massive job'
If the appt is for 1 to 6 then they shouldn't expect you to be available before that!  I suspect you are the first afternoon appt and they've possibly had one of their morning appts cancelled, so they want to move everything forward and finish early!
A normal FTTP install should take no longer than 2 hrs and the engineer won't know if it's going to be difficult until he gets there unless there's been a survey done before .
jelli
I did wonder if that was the case especially on a Friday! I didn't realise it was a 2 hour job though. Thanks for your help Smiley
Fixes: 579
Is your connection underground or overhead ?
jelli
overhead
Fixes: 382
In that case, what is the 'massive job'?
mystreet1
Seasoned Pro
Fixes: 7
Let's not forget, it's Poets day
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 382
Dunno what you're drinking/smoking, @mystreet1 , but it's funny stuff.
Fixes: 579
overhead
@jab1 agreed.
@jelli it should be a simple matter of replacing the existing cable from the pole with a fibre one. The external fibre would normally take a similar route, attached to the eaves similar to the existing cable and then down the building to a new CSP ( grey box ) at ground level. The internal fibre then goes through a hole behind the CSP to the ONT inside. The engineer will need to drill holes to secure their ladder when working at height, they should fill them afterwards.
Not knowing how the property is laid out and where the existing cable and master socket are , its difficult to be precise but do you see any issues with what I've described above ? Note that , unlike the existing master socket, the ONT requires power and so needs to be within 1m of a power socket.
A straighforward overhead install should take around 90 mins.
jelli
crikey, that's quite a job... the replacement of the cable might be a pain as the pole is not in a direct line to my house and he'll have to fix it on my neighbour's - which is where the existing cable is attached. There's a hole in the wall where the current cable is though it's not at ground level. I wonder if he can still use that? There's a power source very near by.
RobPN
Fixes: 15
@jab1
Fairly common knowledge in many circles ...
https://en.wikipedia.org/wiki/POETS_day
jelli
I know, that's what worried me
Fixes: 382
@RobPN wrote:
@jab1
Never heard of it miself, but you learn summat new every day.
Fixes: 579
@jelli
That might be a problem!. There must already be a wayleave in existence to allow routing via your neighbour but if the cable attaches to your neighbour at height ( I assume it does? ) then the engineer will need agreement from the neighbour to secure his/her ladder. Try and ensure your neighbour is available on install day.
The external fibre is spliced to the internal one at the CSP. The splicing equipment cannot be used at height ('elf and safety') so the CSP must be at ground level. So the fibre would normally be clipped down the the wall from where it attaches at the eaves.
jelli
It is at height, yes, the existing one runs across below the gutter and then down my wall to the hole. Thankfully my neighbour is a total sweetheart so I'm hoping that things will go okay.
I'm guessing that's why he has said it was a massive job. I presume this happens a lot when properties are not in line with the pole...
One wonders what happens when the neighbour isn't in agreement.
