Engineer booked Dec - no show
Tamarcrops
Can someone tel me what I am supposed to do ? Sat waiting all morning for an engineer to set up full fibre - now 13.50 and no show - no text no communication from anybody. Do I go out or will I get charged? Taken a day off for this !! I am entitled to compensation, and I am being charged the out of contract rate for the broadband ? Sat on hold , no dialling tone on landline phone now
either ? SOMEONE LET ME KNOW WHATS HAPPENING !! I have Better things to be doing than sat a few days before Xmas for an engineer who doesn’t turn up
10 REPLIES 10
Fixes: 476
Re: Engineer booked Dec - no show
Moderators Note
This topic has been moved from Broadband to My Order
Fixes: 380
@Tamarcrops If you have no dial tone, I suspect the engineers are swapping things round in the street cabinets to connect you.
Fixes: 244
Really?  The day is not yet over...
Ofcom Automatic Compensation Scheme
Plusnet is signed up to the Ofcom Automatic Compensation Scheme - see Automatic Compensation FAQs. Plusnet will pay you automatic compensation in the following circumstances:
  1. Delayed activation of your broadband and/or landline service (if your service isn’t activated by 11.59pm on the date promised to you)
  2. Delayed repair following a total loss of service
  3. Missed appointments
For compensation to be paid, you must have a CONFIRMED date for the failed activity. To see what is happening in detail, check the ticket history on your account - log into the portal in another tab, return here and click the PN TICKET link below. Look at the details of the tickets; if there appears to be no recent activity, contact support.
RealAleMadrid
Fixes: 68
@jab1  It would be more appropriate for Openreach to install the new Full Fibre connection to @Tamarcrops  before they disconnect the existing copper line service. So not sure what's going on.🤔
Fixes: 244
...unless they are using the copper to pull the fibre ... as has happened on numerous installations.
Fixes: 115
@Townman
It they are using copper to pull the fibre cable you would have expected them tp knock on the door and check the install details first. Also, there would almost certainly be a OR van visible on the street.
Tamarcrops
Now been on the phone 1 he 45 mins - it seems they’ve disconnected me !!! It’s like as though neither talks to each other - I’ll disconnect broadband before I’ve checked if the works being done ? Well they had better reconnect as they’ve sent another appointment through and it’s February- I run a business !!!
RealAleMadrid
Fixes: 68
@Tamarcrops  A totally unacceptable situation, have Plusnet given any explanation of what happened and if they can restore the copper service.
I would raise a formal complaint .....
Complaints Code of Practice
adamwalker
Fixes: 223
Hi @Tamarcrops, I'm really sorry to see this. I've picked up ownership of your complaint and will make sure we get this sorted out as soon as we can.
I've added a response to your account here regarding the missed engineer visit and getting a booking rearranged and I'll give you a call later today: https://www.plus.net/wizard/?p=view_question&id=230015089
I'm really concerned about your current connection not working, just to confirm that hasn't been cut off and both our logs and a line tests show that it should be working just fine. Can you let me know what's happening when you try to use the connection?
Adam
 Adam Walker
adamwalker
Fixes: 223
I've just tried calling now but it rang through to your voicemail so I'm sorry if it was a bad time. I've left a voicemail and will try phoning again tomorrow so please let me know if there's a good time between 8am and 4.30pm
Adam
 Adam Walker
