Engineer Dates
bazzer
Engineer Dates
On the order page to upgrade to FTTP, there is a section titled "Book an engineer".
Is this the date of installation, or the date on which an engineer will visit the property to conduct a pre-installation check?
17 REPLIES 17
Fixes: 585
Re: Engineer Dates
@bazzer
First, its only an 'estimated' date until confirmed by Openreach. Secondly, it depends on what your 'Install process' is. Check the btwholesale checker. If its '1-stage' then its the install date. If its '2-stage' then its usually the 1st visit for external work. If its 'KCI2 assure' , then its the date for an initial survey to decide what work is needed.
Fixes: 1,495
Re: Engineer Dates
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 480
Re: Engineer Dates
Helped my next door neighbour to upgrade to Full Fibre on Monday. It is not listed as KCI2 but needs a duct to join that on the pavement as the copper is direct burial, so definitely a two part install. Booked date for later in the month, which I assumed was the survey date. Openreach turned up this morning unannounced to survey the route. I'm now assuming that the booked date is that for the dig team to turn up.
I'll update on the appointed day.
bazzer
Re: Engineer Dates
@MisterW Thank you.
bazzer
Re: Engineer Dates
@Baldrick1 Sounds like it could be a lot of work!
It's this element of installation that gives me some concern as to how much disruption there may be.
I'm hoping that the existing ducting at my home can be utilized.
Fixes: 118
Re: Engineer Dates
@bazzer
Look at the following
Where it says WBC FTTP what does it say to the right?
Below the results window will be a narrative on FTTP - what does this say?
bazzer
Re: Engineer Dates
@bmc Hi Brian.
Fixes: 118
Re: Engineer Dates
@Baldrick1 @dvorak
Any chance of getting this image released from moderation.
Fixes: 1,495
Re: Engineer Dates
should all be good @bmc
Fixes: 118
Re: Engineer Dates
@dvorak
@bazzer
Thanks for the info. You missed out what it says to the right of WBC FTTP.
That aside, the results are showing a "congested duct" - this may be bad news, it may not. The engineer knows in advance what to expect and will try to get a rod through to pull the fibre cable. It they can't then it may involve digging.
bazzer
Re: Engineer Dates
@bmc Sorry, Brian.
Here's the missing part:
bazzer
Re: Engineer Dates
@Baldrick1 @dvorak
Looks like my image is blocked.
Fixes: 1,495
Re: Engineer Dates
Sorted
bazzer
Re: Engineer Dates
@dvorak Thank you.
