Delivery
Ikester213
Delivery
I ordered my fibre broadband package on the 9th of November and the service will go live on the 29th, when should I expect my router to be delivered ?
7 REPLIES 7
Browni
Aspiring Hero
Fixes: 60
Re: Delivery
Normally it's a couple of days before the go live date.
adamwalker
Fixes: 216
Re: Delivery
Hi there, I've just checked your account to be on the safe side and the router is due to be dispatched within the next few days and should arrive in time with you for activation.
 Adam Walker
Ikester213
Re: Delivery
Brilliant thank you, also I live in a set of flats, will they leave the router in the lobby or will they try to deliver to my door, as I'm at work during the day ?
Mav
Fixes: 510
Re: Delivery
Moderator's note(s):
Thread moved from Fibre Broadband to My Order.
Forum Moderator and Customer
Browni
Aspiring Hero
Fixes: 60
Re: Delivery
The routers are sent by Royal Mail in a package that should fit most standard sized letter boxes so it's up to your local postie what happens.
Ikester213
Re: Delivery
Ah okay, thank you for your help!
Beyhive
Fixes: 44
Re: Delivery
No worries @Ikester213,
Let us know if there is anything else we can help with.
 Faris
