Credit checks
carldale123
Credit checks
Good morning, I am completing on my property on Thursday and want to order broadband. I am worried about hard searches appearing on my credit file before ordering and ruining the completion. Does Plusnet run a credit check there are a few places online saying they don’t however I’d like to see if anyone on here can answer.
Carl
6 REPLIES 6
Ripshod
Re: Credit checks
I don't know if it's the same procedure as a new connection, but I setup my move from vodafone this morning and there was no credit check, just the initial payment.
Fixes: 473
Re: Credit checks
Moderator's note:
Thread moved from Broadband to My Order
Katie_J
Re: Credit checks
Good morning @carldale123
Congratulations on the new home!
Plusnet do not complete credit checks for Home Broadband, you will just be required to make an initial payment of one month up front.
Hope this helps,
Katie Smiley
carldale123
Re: Credit checks
Hi @Katie_J
Thank you for your response. If I were to order how long does the router take to come? Just so that I don’t order too early?
Carl
Fixes: 378
Re: Credit checks
@carldale123 the router is despatched by Royal Mail Tracked 24 to arrive 2/3 days prior to activation of your connection.
mwwagain
Fixes: 4
Re: Credit checks
You can though request the router earlier by calling up.
You might wish to have it to 'play with', sort out cabling, or just to be sure it is there if your activation 'goes a bit wonky' and does not follow the normal schedules.
