Account Error
vellfire_
Account Error
I think I've broken my account slightly by changing plan before initial billing.
It seems to be similar to posts like this https://community.plus.net/t5/My-Account-Billing/An-error-has-occurred-You-can-t-change-your-product... where the error is:
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
I want to add an add-on, so with this error I can't proceed in doing so.
Thanks,
Will
2 REPLIES 2
Mav
Fixes: 518
Re: Account Error
When your order is complete you should then be able to add the 'add-on'.
However, if the add-on is a Static IP then I think you'll need the intervention of a staff member.
Forum Moderator and Customer
Fixes: 1,662
Re: Account Error
Hi @vellfire_
That should be sorted for you now. The product change was stuck, despite having already completed.
Let me know if there are any further issues. Smiley
