You have an order which is currently being processed
Rookyroo
I keep having this message, could you sort it for me please.
Thanks, Anna
5 REPLIES 5
adam945
Fixes: 113
Re: You have an order which is currently being processed
Really sorry about that @Rookyroo
I've just sorted that out for you, so that message will no longer appear. Let me know if you have any further issues at all.
 Adam
 Plusnet Help Team - Leeds
Jevets
I am also having this problem when trying to renew my contract, can this be investigated for me:
Ste
Fixes: 1,652
Thanks for your post @Jevets
This should be sorted for you now also.
Let us know if you have further issues or there's anything else you'd need help with.
Jevets
Thanks for sorting the order in progress issue, I find that I cannot change the firewall settings, when I try to save i get "
"An error occurred
Please try again soon. If the problem persists, please let us know."
2 ports that I need to use (port 9 for wol and port 34567 for cctv cameras) are blocked.
Ste
Fixes: 1,652
Thanks for getting back to me @Jevets
We're aware of an issue with changing the firewall settings we're working on getting to the bottom of as soon as possible.
I've taken a look into this for you though and I can see the broadband firewall on your account is turned off, so this doesn't appear to be blocking ports.
It may be worth checking the router firewall at http://192.168.1.254 and using port forwarding to open ports up.
