Upgrading broadband limit
- My Account/Billing
- Upgrading broadband limit
14-06-2013 9:13 PM
I keep phone with bt so that I can use 18185 for very occasional calls to Israel at 2p per minute.
The son and I use one anothers wifi depending on where we are located in our adjoining cottages to pick up the strongest signal.
The option that would suit best would be able to have unlimited on my own account and keep the voip phone.
The other option is to change sons to BT unlimited (£3 extra pm) or to the + TV package (£7 extra pm) so he can make use of the online TV.
I am not keen on the bt option due to bt's call centres.
I get dizzy looking at all the options and would like advice from anyone who has had a similar problem
Mick
Re: Upgrading broadband limit
14-06-2013 9:22 PM
Also Plusnet don't block 18185 either
14-06-2013 9:27 PM
14-06-2013 9:32 PM
Either way to upgrade is dead easy - just go to https://portal.plus.net/index_portal.html?home=membercentretop and click on Product Change in the top menu
Note that it will start a new 12 month tie in and you will keep all your existing addons such as fixed IP, webspace and VOIP
14-06-2013 9:36 PM
A 12 month account is fine and I will look up to see when I have paid up to with bt line rental which I do yearly, then transfer line rental as well
14-06-2013 9:47 PM
14-06-2013 10:19 PM
Just upgraded to 24 month plusnet contract and bt line is being changed to plusnet in August when bt prepayment date is due.
14-06-2013 10:25 PM
15-06-2013 2:42 AM
The only advantage with BT phone service is when there is a telephone outage they normally allow free transfer of incoming phone calls to your mobile though not always. If only plusnet could have something similar in place.
15-06-2013 11:03 AM
