Phone Billing
- My Account/Billing
- Phone Billing
Phone Billing
17-06-2013 7:08 AM
Hi All, can anyone tell me if it is possible to check phone bills from previous months.
Thanks Selkirk.
Thanks Selkirk.
Message 1 of 2
(1,426 Views)
1 REPLY 1
Re: Phone Billing
17-06-2013 9:29 AM
Morning Selkirk,
If you head over to http://www.plus.net/phonebill
On the right hand side at the top you've got "View Bill:" with a drop down menu, pick the one you want and it'll list the calls for you.
Hope this helps,
Matt
Hope this helps,
Matt
Message 2 of 2
(455 Views)
