Unable To Open Ticket
OhItsTom
Hello,
I've noticed our broadband speeds have once again dropped to around 26mb which is simply unacceptable. I tried to open a ticket to request a DLM reset however its saying they are unavailable.
Trying to go the broadband section of my plusnet portal shows me a quick message saying im restricted. Can someone assist me A with my account, and B with my fibre.
Tags (4)
15 REPLIES 15
adam945
Fixes: 113
Re: Unable To Open Ticket
I'm sorry to hear that you're having problems with your speeds again @OhItsTom
Tests on the line show that this isn't a banding issue though. Don't get me wrong, the line is banded at 30Mbps (RRT) but it's only syncing at around 27Mbps, meaning there's likely a fault with the line.
We've also not been able to run a phone line test, which is a likely symptom of a fault, so I've raised this issue to Openreach. No need to create any tickets on your end either, I've just created one for our Technical Support Team to monitor.
You can both view and comment on it for direct communication with them here.
 Adam
 Plusnet Help Team - Leeds
OhItsTom
Thanks for opening a ticket about my fibre issues, but could you advise me on why my account is restricted?
Also why is my line banded at 30, when i've previously had 37-40 speeds? This is all very weird
adam945
Fixes: 113
Thanks a lot for your response @OhItsTom
C an you please clarify what you mean when you ay your account is restricted? For some time now, the only way to raise a Ticket on your account from your end would be if it was a complaint, or if you've gone onto faults.plus.net and raised a fault that way.
In regards to the banding issue, this isn't something we control ourselves, if Openreach's DLM software detects line issues, it sometimes bands the line to preserve stability.
 Adam
OhItsTom
If you look at the first image i attached in my original question, you can see that its telling me my account is restricted any time i try to enter the broadband section of my portal.
Fixes: 1,662
Thanks for getting back to us @OhItsTom
Apologies for the confusion, at first glance it does look like the first screenshot is part of the second which may not have helped. I've checked your account and there's no restrictions from what I can see.
Can you try from a different device and in private browsing mode (incognito if you use Chrome)?
OhItsTom
I have tried with incognito, same problem.
Posted some extra screenshots to help, seems to redirect me to a 404 page.
Fixes: 1,662
Thanks for the screenshot @OhItsTom
Absolutely odd, I'd like to take a closer look. Can I change your account password and log in as you?
Let me know if you're happy for me to by replying to this ticket Here I've created.
OhItsTom
Will do, just answered the ticket, sorry for the late replies im super busy atm
Doesnt seem to be a problem limited to my network as using mobile data shows the same error
Fixes: 1,662
Cheers, no problem Tom.
Yeah I've replicated. Looks like it's a problem with every tab except Add-Ons and Home. :S
Feel free to change the password back. Still none the wiser unfortunately. Sad
I've dropped an email to a colleague to see if they can shed some light on this and to find out who I can go to fix.
OhItsTom
Thanks for the help anyways, not really sure what caused this as i havent logged in in a couple weeks!
adam945
Fixes: 113
Yeah it seems really odd o be honest @OhItsTom
The open Ticket that Anoush created has come off hold so I'm sure he'll be in touch today with a further update on that.
In regards to the phone fault, Openreach are asking us to arrange an internal engineer appointment. Please respond on this Ticket with your availability for a visit.
 Adam
OhItsTom
Just answered about booking an appointment, was busy up until now so couldnt respond!
Fixes: 1,662
No problem Tom, it's all good.
Upon further investigation for your speed fault, our tests are now showing the banding at "Downstream: 0.128M-27.4M with Retransmission (High). Upstream: 0.128M-10M with no error protection" so I've arranged for your line to be reset.
This should go through within the next 3 working days. If your speed drops again, I'd recommend we book an engineer to take a closer look, but at this stage as everything else is checking out OK on your line, I'll reset it for you.
For your account issue however though, I've not got a response back yet from my colleague I've raised this to. I'll be honest as always when I say this likely won't be a quick fix due to the nature of the issue, but I'm monitoring.
OhItsTom
Thats awesome thank you so much, i did originally think it wasnt a physical issue due to the countless previous engineer visits so im glad we arent continuing down that path.
I will continue to monitor the tickets and my speeds, thanks so much for the help from you and others in the forum.
