Transfer referrals
rft
Transfer referrals
After my Plusnet account was unexpectedly ceased I've had to open a new account with a different username.
My old account had two referrals, is it possible to transfer them to the new one?
Roger
11 REPLIES 11
Fixes: 243
Re: Transfer referrals
This is possible technically, but it needs a fiddle, which means finding someone who can fiddle!
One of the staff gurus or wizards who lurk here might know the right tune.
willcutforth
Fixes: 113
@Gandalf might be your best bet if he is lurking in the background.
 Will Cutforth
Fixes: 1,662
Sorry for what has happened @rft
Unfortunately, I can't move the referrals; the system I use doesn't work if the account's cancelled.
This may need someone from the Support team to see if there's another solution.
rft
Thanks for the replies. AAMOI, my old account wasn't cancelled -- it was closed in error by Plusnet. I've had the account for 23 years but apparently,once an account is closed, for whatever reason, it can't be re-opened or so I was told. Are there any Support staff on the forum who can help with transferring my referrals?
Roger
Batfrog
Should be simple - unless things have changed ?
When I moved house my account was closed and a new one with the same name but a '1' at the end was opened, complete with refferals. I think I had about 6 refferals at that time. People have moved, changed ISP or popped off, I'm down to 2 now. Still better in my pocket than .............
Fixes: 243
Re: Monthly direct debit
@rft - I hope you were not using the legacy email service ...
The "new" billing system cannot 'cope' with resurrecting an account: it has been suggested that following the billing system closing an account it can never be reopened.  From a software engineering and data management consideration, that's not true ... but there would need to be user tools to facilitate the change.  Such facilities could though lead to a loss of data integrity, making the option impractical.
rft
Yes I was, but I now have a new account to match my new username thanks to a couple of very helpful people at CS.
Roger
MatthewWheeler
Fixes: 503
Hi @rft
As @Gandalf mentioned, we're not able to move the referrals over because the old account was destroyed.
I've proposed something on a ticket on your account which you can see here.
If you're happy to accept this please let us know
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
rft
@MatthewWheeler wrote:
Hi @rft
Hi Matthew,
I've replied to the ticket. Thanks for picking this up.
Roger
SammyM
Fixes: 101
Ta @rft
All sorted for you, please get back in touch if you need anything else.
 Sammy M - Sheffield Team
rft
@SammyM wrote:
Ta @rft
Thanks Sammy.
Roger
