Phone charges but do not own a phone
rebekah219
Hi there
My bills have been creeping up so I looked at them more closely and noticed ‘extra call charges’ had been applied. Last month was over £10.
I have never ever owned a home telephone so have not used the landline.
Why is this happening and how can I get it sorted?
Rebekah
5 REPLIES 5
Fixes: 334
Re: Phone charges but do not own a phone
@rebekah219 If you check the list of 'called' numbers, what are they?
rebekah219
A lot of ‘123’ at 50p a time and a few longer calls to local landlines.
Very frustrated because it’s tripled my bills and I haven’t used a landline in over 10 years!
RealAleMadrid
Fixes: 66
@rebekah219  Calling 123 is something phone engineers do to check for spare lines but it can also be caused by an intermittent connection on the line. If the other numbers are all low digits 1234 etc that is almost certainly a line fault.
Fixes: 334
Just typing almost exactly the same, @RealAleMadrid .
@rebekah219 I would call Plusnet as soon as possible tomorrow morning and dispute the charges.
Fixes: 1,642
Hi Rebekah,
I'm really sorry for what's happened.
I see we've found a fault and reported it to our suppliers so an engineer should be looking into that soon. If you can let me know when it's fixed, depending on the outcome of the fault, I'll arrange for those call charges to be refunded back to you.
