My Circular (Denied access)
- My Account/Billing
- Re: My Circular (Denied access)
11-07-2014 1:01 AM
Quote Access to component denied
Sorry, you do not have access to the My Circular application at present.
Can you advise when this will be up & running ?
11-07-2014 9:00 AM
11-07-2014 9:04 AM
Quote My Circular is available to residential customers and those using Teleworker products. Business customers get a similar but more powerful application called NetAnnounce.
11-07-2014 9:06 AM
I've just tried it and it still works.
11-07-2014 9:07 AM
11-07-2014 9:08 AM
11-07-2014 9:16 AM
However it does say (my bold red):
Quote from: Bob Please note that this notice refers to our mailing list service only and *does not* apply to either the Net Announce or My Circular services that some customers have access to.
I think we need clarification from Plusnet on this.
11-07-2014 9:25 AM
I can confirm that we stopped bundling this with new accounts quite some time ago however if you had it prior to this, you would still keep even when changing account types to the newer packages (unless requested otherwise). In this instance, the account was only signed up in 2013 so wouldn't have been available on any of the products we offered in the sign up journey.
I'll see if I can dig out the date that we decommissioned it however, from memory, I think we just stopped adding it into the bundled services as it wasn't something we had advertised for some years.
11-07-2014 9:29 AM
Quote from: jelv I think that it appears on your menu is possibly an error.
11-07-2014 9:36 AM
11-07-2014 9:39 AM
11-07-2014 9:57 AM
11-07-2014 10:14 AM
UPDATE - For visibility I've raised this to the Wen Team under PID: 81995
11-07-2014 1:23 PM
Quote from: Adam <snip>
Yes the account was setup in December 2013
Quote from: pwatson Not that I'm bothered, it also shows in my Member Centre and doesn't work... Not so much an error as a left hand, right hand disconnect perhaps?
Same here, although this is what mine currently looks like
Cheers for raising this Adam
I did not think it was an issue tbh
11-07-2014 4:38 PM
It's a tough one with it being a legacy service, it's that old that it was never designed to be on some accounts and not other which means everyone will have the link for it but only those with the active component for it will be able to gain access. Ideally the link should only show if you have the component as well as the support page reflecting that this is no longer an active service unless your account was signed up before X date.
Hopefully the request I raised will see some traction soon and we can get the changes implemented
