Migrate DSL to FTTP and keep static IP?
cdnt
Does anyone know if I can upgrade from DSL to FTTP using the member centre website and keep my static IP address or do I need contact customer services or to do anything special?
2 REPLIES 2
Fixes: 383
Re: Migrate DSL to FTTP and keep static IP?
@cdnt If you upgrade from FTTC to FTTP with Plusnet on the same account, you should retain the static IP - It is tied to the account, not the service. In the unlikely event that it does get 'lost' in the upgrade, a post on here requesting restoration will fix it.
cdnt
Thanks @jab1  - I will give it a go soon and see what happens...  Hopefully all smooth but will start a new post if I need it restored.
