Migrate DSL to FTTP and keep static IP?
FIXED- Subscribe to RSS Feed
- My Account/Billing
- Re: Migrate DSL to FTTP and keep static IP?
20-02-2026 4:55 PM
Does anyone know if I can upgrade from DSL to FTTP using the member centre website and keep my static IP address or do I need contact customer services or to do anything special?
Fixed! Go to the fix.
20-02-2026 5:09 PM
@cdnt If you upgrade from FTTC to FTTP with Plusnet on the same account, you should retain the static IP - It is tied to the account, not the service. In the unlikely event that it does get 'lost' in the upgrade, a post on here requesting restoration will fix it.
20-02-2026 5:20 PM
Thanks @jab1 - I will give it a go soon and see what happens... Hopefully all smooth but will start a new post if I need it restored.
