Line Rental Saver - can't renew
Pallathu
I have  received the email informing me my LRS is about to expire.  If I go to the LRS portal link as supplied it says
"You're already signed up for Line Rental Saver.
This will start from your next billing date."
The same message appeared before on the previous bill.
My current LRS expires on 21/02/2021 and I have not renewed it yet.
Please help.
Thank You.
7 REPLIES 7
hooverman
Re: Line Rental Saver - can't renew
hi @Pallathu  from what inderstand they are withdrawing the line rental saver possibly by the 18th feb ,Plusnet indicated they were going to stop LRS in April last year, I suggest you contact Plusnet to see how your case should be handled because I think that we are going to have to pay a monthly line rental rather than a lump sum every 12 months
Thrall
Seasoned Pro
Fixes: 23
@hooverman I read another post on here (I can’t remember the post) say that you can renew line rental saver one final time before it’s withdrawn.
Sounds like the OP’s issue is something different
[edit]
Found it https://community.plus.net/t5/My-Account-Billing/Confusion-over-line-saver-rental-renewal-date/m-p/1...
Pallathu
Thank you.
Pallathu
Thank you for your reply.
Fixes: 1,601
@Pallathu I've got this fixed for you, you should be able to renew now by going to plus.net/rentalsaver
Fixes: 1,484
Moderators Note
This topic has been moved from Home Phone to My Account / Billing
Pallathu
Thank you problem solved.
