Help assistant
Bolette
Help assistant
I am new and have trouble finding help assistant to update a support queation raised - can anybody point me in the right direction? Thanks.
13 REPLIES 13
Legend
Fixes: 258
Re: Help assistant
If you have raised a question, just log into your account - it should be on the homepage.
Bolette
Re: Help assistant
Yes, I can see it but the email said you were able to add comments? Can't see that option...
Legend
Fixes: 258
Re: Help assistant
If you open the question - right at the bottom, it should say something like 'I need to add further comments'.
Bolette
Re: Help assistant
Nada and in the email I only get an option to review.
Legend
Fixes: 258
Re: Help assistant
Ignore the email - open the question from the portal, and you should get something like this at the bottom:
Fixes: 420
Re: Help assistant
@Bolette
You cannot communicate with or reply to Plusnet via emails. They simply do not receive them, or if they do, delete them on receipt without reading.. As advised, reply to the ticket.
Bolette
Re: Help assistant
Nope, when I log in to my account it shows the question and that's it. No otjer options. Maybe it's because I am new....
Legend
Fixes: 258
Re: Help assistant
Try clicking on 'view' - far right.
Fixes: 406
Re: Help assistant
Its possible that the question has been raised as a 'closed' one. In which case there will be no option to add further details
Legend
Fixes: 258
Re: Help assistant
If it is showing on the OPs home page - it should be possible?
Bolette
Re: Help assistant
No, it just shows the whole messag but no navigations options at all.
Bolette
Re: Help assistant
Ah, must be down to the cs as I was able to see and comment on my latest query. Thanks again for all your help. 👍
Legend
Fixes: 258
Re: Help assistant
Deleted - irrelevant.
