Failed billings
- My Account/Billing
- Failed billings
Failed billings
16-01-2019 8:14 AM
So I had a payment due on the 7th that failed to go through, ive updated the payment information but now i'm having restrictions on my account. If someone could take a look and sort it quick I'd be grateful
Re: Failed billings
16-01-2019 10:09 AM
hi,i've been waiting for a payment to be taken since 27 dec 18,when i contact them i just get fobbed off,as i'm a pensioner and i have set payments i think this is unacceptable,i'm now on the phone waiting upto 15 mins for them to answer.
Re: Failed billings
16-01-2019 12:11 PM
Hello @HurgleFurgle
I have amended and updated your account, you should now be able to use your services as normal.
You may need to perform a Master Reset on your router to remove the restrictions.
Use a paper clip, pen, or something pointed to press in the reset pinhole button on the back of the router.
Keep the button pressed for 20 seconds. When the light on the front of your Hub turns green, release the reset button.
When the light on the front of the Hub turns blue, it's now restored to factory settings.
Keep in mind that if you do this, it'll completely restore your router to the settings it had when it arrived. So if you've made specific changes to your settings, they'll need to be made again.
Should you require any further assistance, please do get back in touch with us.
Best wishes.
Re: Failed billings
16-01-2019 1:56 PM
Hello @pat7762 I am deeply sorry to hear you have not received any invoices from us recently.
I have responded to your query via a ticket. You can view this by Clicking Here
Many thanks.
