Change bank account
ejohnh
Change bank account
HI,
I want to change the bank from which I pay the direct debit.  Is there an online way of doing this?
Having spent the last couple of hours trying to find a way I thought Id ask the experts Smiley
Thanks,
E John
Tags (1)
1 REPLY 1
Fixes: 235
Re: Change bank account
Hi John,
Yes, it is an easy enough to do task ... but a wee bit tricky due to an elusive issue with the user centre rendering.
  1. Log into the user portal
  2. That should present a "your bill box"
  3. Click the "edit payment method" link
  4. Scroll to the bottom of the page - you should be able to see your current payment method just above the black footer
  5. Resize the browser window by whatever means (minimise / restore down / maximise)
  6. That will move the black footer out of the way exposing the Change Payment Method button
Superuser citation
This topic has been cited by one of the Superusers; the purpose of which is to provide a note for information which might help to focus continued discussion (but might not result in a staff response).
