Cannot add voicemail feature as 'order currently being processed.'
- My Account/Billing
- Cannot add voicemail feature as 'order currently b...
11-11-2020 5:21 PM
Hi trying to add voicemail to my account, however the option to add this feature is greyed out as I can see the following status message:
"Unable to change service
You can't change your products for the moment, you have an order which is currently being processed. Please try again later."
What do I need to do to update the order status (I assume I will be able to add the voicemail feature then).
Thanks in advance.
Message 1 of 2
(343 Views)
1 REPLY 1
Re: Cannot add voicemail feature as 'order currently being processed.'
11-11-2020 8:48 PM
I have joined the forum because I also have this issue. Rather than start a duplicate thread, I thought I would add to this one.
