Call threshold nearly reached
- My Account/Billing
- Call threshold nearly reached
11-04-2020 12:04 AM
Re: Call threshold nearly reached
11-04-2020 8:52 AM
Usually a new call plan only comes into effect at the next billing date and you remain on whatever plan, if any, you are on until then. Have you had a bill since you signed up to the Unlimited UK & Mobile call plan or did Plusnet specifically indicate that the plan was starting on 18 March?
11-04-2020 9:49 AM
11-04-2020 10:45 AM
With luck someone from Plusnet will pick this up here.
I suppose you could top up your credit on the basis that would keep you going and Plusnet should reimburse you once they see their error and sort it out. Best of luck!
11-04-2020 12:05 PM
