Bt id
Wayne68
Bt id
Hi does anyone know how i can find out my bt id from plusnet
7 REPLIES 7
Fixes: 244
Re: Bt id
BT ID in what context?
Mustrum
Fixes: 81
Re: Bt id
What BT ID?
What is it you are trying to do?
RealAleMadrid
Fixes: 68
Re: Bt id
@Mustrum  Probably related to BT Sport from Plusnet which needs a BT id to login, it is usually, but not necessarily your email address and there will also be a password, I would expect these would be set up when first accessing the service.
Wayne68
Re: Bt id
Im am trying to get on bt sport with my google chromecast but when i try to register it asks for my bt number or my bt id and im not with bt
RichardB
Seasoned Champion
Fixes: 39
Re: Bt id
Follow the instructions re using the BT sport app at:
https://www.plus.net/help/bt-sport/bt-sport-app/
Fixes: 146
Re: Bt id
@Wayne68
you should have received an email from plusnet on how to activate the BT sport app, the BT ID is the email address I used is the one I used when following these instructions.
Instructions I received
Your BT Sport App from Plusnet
Before you can get started, you'll need to register. Don't worry, we've got 7 simple steps below to get you all set up:
Step 1: Go to this link
Step 2: Enter your Plusnet username and postcode.
Step 3: Enter your personal and security details.
Step 4: If your email is not already registered for a BT ID, you'll be asked to create one. If your email is already registered for a BT ID, you'll need to login using your existing BT details. If you've forgotten your details, you'll be asked to reset your password to validate your email address and reactivate your BT ID.
Step 5:You will receive a confirmation email from BT to the email address you used in the registration. Please open this email and click 'Activate your BT ID', then follow any additional steps.
Step 6: Download the BT Sport App.
Step 7: Log in to your new BT Sport App and enjoy some sport
HTH
Fixes: 475
Re: Bt id
Moderators Note
This topic has been moved from Broadband to My Account/Billing
