Bizarre charges
Fixes: 382
Re: Bizarre charges
OK, @Dan_the_Van , but if @evasz is not even in the UK, is it possible the house is currently unoccupied?
Fixes: 147
Re: Bizarre charges
@jab1
Not really sure what point your are trying to make, I know they are not in the country and they have no phone connected, so something is making calls.
If you have an issue PM me!
evasz
Re: Bizarre charges
Thanks jab1! Much appreciated.
Dan - I can assure you there is no physical phone at my property - I only pay for the line rental to get my broadband. It is also unoccupied at present, but without an actual phone even a ghost dial would be tricky Smiley
I have had my broadband for 18 months now and there has never been a single landline call so surely Plusnet will be able to see something dodgy is going on…
Fixes: 382
Re: Bizarre charges
No issue, @Dan_the_Van  - just didn't don't quite follow you.
However, I'm only going to answer when it helps hopefully) the OP.
RobPN
Fixes: 15
Re: Bizarre charges
@jab1 and @Dan_the_Van keep your hair/wigs on!
As pointed out by @Mustrum and @Townman very early in the thread, there is almost certainly a fault on the line causing the calls to be made, which can be as simple as a broken/intermittent connection on a dropwire which is blowing in the wind.
Fixes: 382
Re: Bizarre charges
@RobPN What little hair I have left is still firmly attached. 😀
Fixes: 382
Re: Bizarre charges
@willcutforth  - any chance of looking at this issue?
willcutforth
Fixes: 113
Re: Bizarre charges
Had a gander @jab1 and as expected fault on the line. I am raising it now for you @evasz
 Will Cutforth
Fixes: 382
Re: Bizarre charges
Thanks, @willcutforth .
evasz
Re: Bizarre charges
Thanks for looking into this!
evasz
Re: Bizarre charges
And thank you so much for escalating jab1!
evasz
Re: Bizarre charges
Mystery solved: rats have partially bitten through the cables outside, causing the mystery calls. Just when you think you’ve heard everything 🤣🐀
Thanks again everyone!
Fixes: 382
Re: Bizarre charges
Glad it is sorted, @evasz .
