Address lookup incorrect
AM100
I am wanting to look at the upgrade options for broadband on my account. However the address lookup is showing an incorrect address. My address is XX Hurlingham Square, Peterborough Road, London SW6 3DZ. The lookup is returning XX Peterborough Road, London SW6 3DZ. This is a valid address but not mine hence I cannot see what upgrade options are available.
3 REPLIES 3
Fixes: 146
Re: Address lookup incorrect
@AM100 welcome to the forum
You should be able to find the services available to you by using your UPRN https://www.findmyaddress.co.uk/search
HTH
Edit: suggest removing personal data from your post
Use this link https://www.broadbandchecker.btwholesale.com/#/ADSL
AM100
Thanks very helpful. I can see that FTTP is available to my telephone number.
Fixes: 1,662
Hiya, I've updated the address on your account so that it matches Royal Mail's Postcode Address File (PAF) although it looks like you've since still managed to place your order for full fibre.
Let us know if there's anything else you need help with.
