Account Error
KelvinHunt
Account Error
Trying to look at renewing my contract but keep getting faced with this
Unable to change service
You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
6 REPLIES 6
Fixes: 392
Re: Account Error
Welcome to the forums, @KelvinHunt .When did you last make any material change to your account?
You will need a staff member to sort this - the (supposedly) automatic method of clearing this message on completion of account changes is totally broken.
KelvinHunt
Re: Account Error
@jab1 Last change to account would have been 18 months ago when i renewed last
Fixes: 392
Re: Account Error
OK. Hopefully, one of the Help Team will pick this up tomorrow and sort it for you.
Chrisvesey
Re: Account Error
I altered my account settings and removed the anytime calls and now have the same problem
Chris
Fixes: 392
Re: Account Error
@Chrisvesey Your account should also get corrected.
Fixes: 254
Re: Account Error
@Chrisvesey
Has there been a billing event since you made that change?
Can’t change product message
It is not possible to make further changes to an account whilst some changes are still in progress. This notice will be displayed when...
  1. A change has been made to an account which is due to happen on the next billing date, such as a change in broadband service or telephone call plan
  2. A change to service (typically phone service options) awaiting confirmation of activation from BT Openreach
For the first of these, the message will disappear after the next billing date. For the second, intervention by a staff member will be required to check that the changes made within Plusnet's systems have been confirmed within BT Openreach's systems.
