Unable to access 4G services whilst roaming
FIXED- Subscribe to RSS Feed
- Mobile
- Unable to access 4G services whilst roaming
Re: Unable to access 4G services whilst roaming
27-07-2022 4:53 PM
@Gandalf - thanks for your help in escalating the issue, out of interest, what was the problem?
27-07-2022 5:18 PM
27-07-2022 5:18 PM
@superpp71 wrote:
For anyone about to travel, you can get a 5gb SIM with EU roaming for £2.45 from LycaMobile currently via uswitch.com
It's a rolling month contract, so just cancel within the month.
I'm going to get one of these and pop it into my 2nd SIM slot, my wife can then use me as a hotspot too.
Hi Depending what phone you have some phones only allow you to have one 4G slot the other is 3G so you will have to check
Good luck 🤔🤔🤔
27-07-2022 5:29 PM
@Gandalf wrote:
Based on the information I’ve got, this issue should be fixed for all. I don’t have full details to be able to properly comment on what the problem was though.
That is excellent news! Hopefully it really does fix roaming issues in all EU countries.
I doubt we'll ever know exactly what went wrong. Since it was such a quick fix I suspect someone *cough* forgot *cough* to enable a switch somewhere…
27-07-2022 8:37 PM
28-07-2022 8:13 AM
Glad someone found the switch 😜
Team, you’ve done well persuading Plusnet to look for the switch and I hope next time I’m away, I can go on a map again 🤣🤣
28-07-2022 11:10 AM
28-07-2022 12:07 PM
28-07-2022 12:40 PM
29-07-2022 5:31 PM
29-07-2022 9:12 PM
Thank you for your efforts guys
30-07-2022 9:32 PM
01-08-2022 12:06 PM
03-08-2022 4:02 PM
We are back there soon, so will see if the 'fix' has indeed been fixed and will post an update.
03-08-2022 4:09 PM
For me TMobile 4G is now working reasonably well in some areas of the Netherlands (wahoo!). The default network (KPN) does not work on any connection type currently.
- Mobile
