Smart Cap basic question
aesmith
Fixes: 4
I couldn't find the answer, sorry if it's there in an obvious place.   My question is whether the Smart Cap is an incremental value, or a total value.  For example say my normal monthly rate is £5.00 and Smart Cap is £10.00 - is the limit in any one month £10.00 or is it £5.00 + £10.00 = £15.00?
Thanks, Tony S
2 REPLIES 2
flanzm
Fixes: 15
Re: Smart Cap basic question
The Smart Cap is the maximum amount you will pay for additional charges over your base subscription.  So in your example the maximum bill you would get is £15 (£5 + £10 smart cap).
Fixes: 1,587
Hi Tony.
My reply is pretty much confirmation that @flanzm is spot on with how the smart cap works. Let us know if you have any further queries.
