Poor coverage
Anon
Poor coverage
Struggled for 2 or 3 months but I find coverage very poor. None indoors, little outdoors and I have done a little Uk travelling in that time and in many places no EE coverage but my Vodafone has been good. So will be moving.
Whatever happens always remember "We will do you
.........................proud" say Pnet.
2 REPLIES 2
SarahStewart
Fixes: 6
Re: Poor coverage
Hi Anon, thanks for getting in touch!
I'm very sorry to hear you're having some issues with your coverage.
It sounds like a new SIM may sort this issue out for you.
If you drop me a private message I can certainly look into this for you.
Anon
Re: Poor coverage
Thanks for the help in PM's, but will not help, it is a new sim, so will move to Vodafone, they are slightly better here, best of a bad bunch in this area.
