Plusnet Mobile reception not as good as EE
- Mobile
- Plusnet Mobile reception not as good as EE
10-11-2018 8:35 AM
Re: Plusnet Mobile reception not as good as EE
10-11-2018 9:46 AM
I think this is true for most, if not all, these "piggyback" providers.
I use a provider, owned by Three and using their network. I have found that the performance is nowhere near the same as Three.
I was with Three for quite a while then tried PN Mobile very briefly (minutes!). After finding the same as you and in spite of them using the EE network, it was not good at all.
10-11-2018 10:01 AM
Quote from Plusnet's mobile T&C's:
"We cover 99% of the UK population, Proud to be part of the EE network”: Either 2G, 3G or 4G coverage of 99.63% of the UK population as at 30 September 2016. Based on EE data.
That comes close to implying that PN's mobile reception will be the same as EE's but manages to avoid mentioning that Plusnet only has access to 1 of the 2 wavebands that EE uses.
Clearly this means that PN mobile coverage will be inferior to EE's in some circumstances (something that many users will have probably suspected for some time.)
This is of course reflected in the price - caveat emptor...
10-11-2018 7:35 PM
Hi there @annew, just to confirm we use EE's network and have the same coverage. Is it just these areas that you have problems? Are they just related to SMS/calls or do they include mobile data to?
10-11-2018 8:10 PM
Clearly that is not true, whilst PN has use the EE network, they do not have access to all the frequency bands, therefore coverage is not as good in some areas. The subject has been mentioned many times before, it is very disappointing to see staff members claim they have the same coverage as EE.
11-11-2018 7:39 AM
11-11-2018 9:57 AM
EE use three 4g bands
800Mhz band 20 1.8 Ghz band 3 2.6 Ghz band 7
PlusNet don't use the 800 Mhz
EE allow BT mobiles to use this but for some reason not PlusNet may be cost
This may answer some questions
The 800MHz frequency band is one of two which was auctioned by Ofcom in February of 2013. Previously this band was used to provide analogue television signals, but since TV’s switched over to digital it was freed up to be used with 4G.
The lower the frequency of the band the further it can travel, so the 800MHz band is the most adept of the three at travelling over long distances, which means users can get a 4G signal even when they’re a long way from a mast. This becomes particularly useful in rural areas where masts are likely to be quite spread out.
However, it also has some advantages in cities, because low frequencies are also good at passing through walls and other physical objects. So the 800MHz band is good for indoor coverage and for heavily built up areas where a signal might otherwise struggle to travel.
On the other hand it has a comparatively low capacity, as it was only available in small 5 and 10MHz blocks, which means that it can’t always deal brilliantly with lots of people trying to connect at once, particularly if they’re carrying out demanding actions such as streaming HD video. So even in places with a good connection it may not always deliver consistent speeds, especially in urban areas where there’s likely to be a lot of data traffic.
Brian A
11-11-2018 12:46 PM
Thanks to everyone for their helpful if somewhat depressing replies. Looks like I will either have to live with it or move again.
12-11-2018 4:25 PM
This statement seems just a little bit naughty really, to say PlusNet has the same coverage as EE. For as long as there are locations only served by 4G800 (and they do exist), then it cannot be true..
I could quote examples, but I'm not sure it would achieve anything.
20-11-2018 7:04 PM
I was thinking off moving my mobile to Plusnet as some of the deals are great - but a relative turned up (already on Plusnet mobile) and had no coverage at my address. This was in contradiction to what the automatic checker said. I read this thread and spoke to the online chat person about the difference between the bands and how they affected indoor coverage in particular - they were completely unaware that there was less coverage on Plusnet than on EE and tried to convince me it was exactly the same.
Is this right that Plusnet indeed has 'less' coverage / bands than EE please?
20-11-2018 7:33 PM
Ok, here goes!!
EE operate their 4G across multiple frequency bands... 1800Mhz is the base layer, 2100Mhz & 2600Mhz additional capacity layers which all the resellers have access to.
They also use 800Mhz for a low-capacity extra coverage layer, this band is better at covering rural areas and indoors but for legitimate technical reasons is restricted to EE & BT-Mobile 4G-calling/VoLTE customers.
It doesn't surprise me in the slightest that CS reps (not just PN, but on other MVNOs too) are unaware of this, I've had a webchat agent from one of the other resellers swear blind to me that they had access to every single EE frequency and specifically included 800Mhz in that.
http://www.matt.qa/ee/ is an entirely unofficial web checker (I'll run the risk of posting this, and hope this post/link isn't deleted) that breaks down coverage at any given area into different frequencies, you can check on here whether there is 800Mhz service at your home that would provide exactly the symptoms you describe. I'm pretty sure the PlusNet & Virgin Mobile web checkers do make allowances for 4G800, but the EE online map has a bug and doesn't currently differentiate.
20-11-2018 7:34 PM - edited 20-11-2018 7:37 PM
20-11-2018 7:36 PM
Hi wickyb
I think you have answered your own question is your relative is already on PlusNet and gets no signal there is a very good chance you will be the same.
A test you could do is to put their sim into your phone and see if that works as there is a different between various make/types of phones.
Brian A
20-11-2018 7:56 PM
Thank you - wise community friends ! Your comments are much appreciated and my mind is made up to not move to Plusnet Mobile. I had almost believed what the CS agent said that there was no difference (and as I run an EE phone for work know that it gives me good coverage at home). Now I know why !
20-11-2018 8:17 PM
Ultimately it's in the nature of MVNOs to sell at the budget end of the market, and you really can't blame them. If you don't want all the extra bells, whistles & services of the main networks but just need a plain vanilla calls & texts service, then there's clearly a market for resellers to reduce costs and sell cheaper as a result.
Where they fall down is when the "no frills" includes features such as VoLTE, which has technical implications which aren't made clear. I've just tried a sample postcode where EE 4G coverage is only on 800Mhz (IV22 2JX) and the PlusNet map does correctly claim no 4G coverage, so there's no cause for complaint there.
Ultimately you pays your money and takes your choice, as to whether the "luxury" or "value" option is best suitable for you.
- Mobile
