Plusnet Mobile - Number Porting
- Mobile
- Plusnet Mobile - Number Porting
Re: Plusnet Mobile - Number Porting
27-03-2017 6:22 PM
6 days and counting still waiting for my number porting over.
27-03-2017 7:07 PM
HI Andy, I feel your pain but I thought that my 6 days waiting was because of a rush for joining the newly launched mobile contract in December 2016. Keep on nagging them as often as you can. It will happen. Good luck
31-03-2017 11:57 AM
Just ported number from Plusnet to Virgin without issues all went through smoothly at around 8 this morning
Request was made yesterday
01-04-2017 1:51 PM
So after 9 days waiting they managed to port my number . Of course with Plusnet nothing runs smooth now i have no data connection. i'll be phoning monday and asking for my port code and moving to a competant company
02-04-2017 10:16 AM
Hi andycass,
Thanks for getting in touch with us, it's much appreciated! I'm sorry if there was a delay with your port in, this is certainly not our usual high standard of service that we provide and we take on board all feedback to help us to improve as a network provider!
On occasion, there can be times that you're port can experience a snag within the number transfer, which can result in a delay with the overall process; if this happens, it is raised with our Operations Team for further investigation.
It's great to hear that your port has now fully processed! Now we need to get that data connection sorted so you're good to go!
After a port has completed, we advise to re-boot your handset; you can do this by the following:
- Turn the handset off
- Take the SIM card out
- Leave it for a couple of minutes
- Replace the SIM card
- Turn the handset back on
This refreshes the signal to the SIM and any changes that have been implemented, will be applied upon re-boot.
You can also input your APN settings, which are listed below:
Android
- Go to Menu > Settings > Wireless & Networks (or More) > Mobile Networks > Access Point Names > Menu > New APN
Without changing any other settings, type in the following info:
APN: everywhere
Username: eesecure
Password: secure
MMSC: http://mms/
MMS Proxy: 149.254.201.135
MMS Port: 8080
Authentication type: PAP
APN type: If there's a choice, choose internet+mms. If the keyboard appears, type * -
Tap Menu, then Save
- To start your new APN, make sure the line is ticked or the radio button is lit by tapping on it.
- Check the notification bar for 4G, H, 3G, E or G with up and down arrows beside it. That'll show your connection is working.
iPhone
- Go to Settings > Mobile or Cellular > Mobile Data Network or Cellular Data Network > Access Point Names > Menu > New APN.
For Mobile data:
APN: everywhere
Username: eesecure
Password: secure
For MMS:
APN: eezone
Username: eesecure
Password: secure
MMSC: http://mms/
MMS Proxy: 149.254.201.135:8080
MMS Max Message Size: 1048576 -
Tap the left arrow at the top three times, then press the home button.
- Check the notification bar for 4G, 3G, E or GPRS. That'll show your connection is working.
BlackBerry
For BlackBerry 10 devices, you need to enter the internet APN and MMS APN settings separately
Internet APN
- Swipe down from the top of the home screen.
- Go to Settings > Network Connections > Mobile Network > APN
- Tap on the Mobile Plan selector and choose Contract or Prepay
Without changing any other settings, type in the following info then tap Save:
Access Point Name: everywhere
Username: eesecure
Password: secure -
Check the notification bar for 4G, 3G, H, E or G. That'll show your connection is working.
MMS APN
- Swipe right from the left hand side of the home screen to get to your Hub.
- Go to Menu (the three dots) > Settings > Text Messages > Advanced
- Scroll down to below the SMS settings.
For APN:
APN: eezone
Username: eesecure
Password: secure
For MMSC:
MMSC URL: http://mms/
Proxy URL: 149.253.201.135:8080 -
Tap Save
Windows Phone 8
- On the home screen, swipe across to bring up the apps list.
- Open the Settings app.
- Tap Mobile Network and check data connection's switched on.
- Go back to the apps list, scroll down and tap Settings
- Tap Access Point
- If your network name's showing, tap it to make it active. Otherwise, choose Add.
Connection name: EE Internet
For internet APN:
Access point name: everywhere
Username: eesecure
Password: secure
For MMS APN:
Access point name: eezone
Username: eesecure
Password: secure
Proxy address: 149.253.201.135
Proxy port; 8080
MMSC address: http://mms/ -
Tap the tick at the bottom to save
- Check the notification bar for 4G, 3G, H, E or G. That'll show your connection is working.
Windows Phone
- On the home screen, swipe across to bring up the apps list or tap the ‘right' arrow
- Go to Settings > Mobile Network > Add APN
Name: EE Internet (if there's the option, tick the box to make this the default APN)
For Internet APN
APN: everywhere
Username: eesecure
Password: secure
For MMS APN
MMS Access Point Name: eezone
Username: eesecure
Password: secure
Proxy address: 149.254.201.135
Proxy port: 8080
MMSC address - http://mms/ -
Tap the tick or disk icon to save, then confirm the change.
Feel free to get in touch if there is anything else that you need and I'll do my best to help!
- Rebeka
02-04-2017 10:20 AM
@RebekaPreston - Did you say something.
02-04-2017 10:24 AM
Hi Mook,
I got a bit confused! I though it was April fools today!!!
Nah, my chrome crashed and kept refreshing, hence the result! Now I have to sit and delete one by one!
Ah well!
- Rebeka
03-04-2017 12:52 AM
Tried the APN settings tried the sim out overnight tried everything suggested in all other threads. Still no joy. The thing is data connection worked perfect on the sim until the number port. I should not have to spend hours and hours searching through forums to make something that should have been straight forward work. Hopefully i will get my payment refunded and i can move back to the tesco mobile a company where i had no problems with and didn't have to jump through hoops to get to work.
05-04-2017 3:45 PM
Hi andycass,
I'm really sorry to hear about this and I'd like to help. If you could send me a private message with your account details, I'll be able to look into this further for you.
- Rebeka
07-04-2017 11:13 AM
I have exactly the same problem, after a late port on Wednesday there is now no data, and I've checked the APN settings and reset multiple times.
09-04-2017 7:56 PM
Don't expect them to be in a rush to fix any problems. The replies on the forums from the plusnet team are just for show. 3 weeks later and i'm still waiting to be able to use the sim card what i paid upfront for. So despite taking all my info last week ive had zero contact from them . Can someone from plusnet tell me how much your going to refund me for all the messing about and if the problems actually ever get sorted or will it just be another sympathetic reply on the forums where nothing actually gets sorted?
11-04-2017 11:36 AM
I am also having a similar porting problem with Plus.Net - on Day 6 now of a port and have had absolutely no service for over 12 hours now on either my plus.net number or my old number. Trying to decide whether to waste time on another phone call to them or not to be told sometimes it just takes time once the port has started.... A friend who was porting at the same time is having the exact same problem.
11-04-2017 11:43 AM
11-04-2017 3:12 PM
Well just spoken to Plus.Net on the phone - apparently my port is complete though I have no service for voice or data, but nothing to do with the port - my sim must be faulty.
So a new sim is being sent out (1 to 2 days), and if that doesn't work only at that stage will they refer it to their operations team. And they will respond within five days.
Seriously - what type of network is this. I repeatedly ask if the adviser i was speaking to if he felt this was good customer service and he dodged the question every time.
11-04-2017 6:45 PM
- Mobile
