Plusnet App with multiple sims
nbatters
I have 4 sims on the same Plusnet account (wife and kids), but cannot seem to find a way of them inputting their own details into the App to see usage etc.  Anyone with a solution please.
7 REPLIES 7
Fixes: 311
Re: Plusnet App with multiple sims
I've only got one sim, but the mobile app uses the mobile number to log in doesnt it ?  Each of the sims must have a different number so surely logging in with a number will give details for that number
Or are you saying that doesnt work...
nbatters
Yes it works for me as the main account holder, but when I put the other phone numbers in it says account details not recognised! Think I will need to speak to plusnet
Fixes: 311
When you received the other sims , did you get an email from Plusnet mobile ?
That should have given the account number for that sim. If you've got those, and the account numbers are different then try using those to login
OllieC
Fixes: 46
Hi @nbatters
We're sorry to hear you are experiencing difficulties.
With this type of query, we would advise calling in by dialling 500 from your Plusnet handset.
Kind regards
nbatters
Thank you for your comments. All sorted now.
Fixes: 311
@nbatters Would you care to enlighten us as to what made it work please ?
So others with similar problems can benefit  in future
nbatters
Had to set up individual passwords for each phone number, thought the original one would work as all sims associated with same account. However, each phone number required setting up a password. Each sim now shows usage on individual Apps.
