PlusNet Mobile App
- Mobile
- PlusNet Mobile App
PlusNet Mobile App
09-07-2022 9:43 AM
How can I delete accounts on this app which are no longer active
When I open the relevant inactive account is gives "Can we temp you back"
These are 30 day rolling Data contracts which require deletion
Message 1 of 3
(307 Views)
2 REPLIES 2
Re: PlusNet Mobile App
12-07-2022 4:34 PM
Hiya @Bures3, thanks for getting in touch. If you could try uninstalling and re-installing it, that might remove the other accounts from the app for you if you can give it a go?
Message 2 of 3
(230 Views)
13-07-2022 5:56 AM
That seems a plausible idea
Re-install and reload the active packages
I will give that a go
